Basic question about writing a differential equation related to finite element
Old   April 9, 2014, 09:12
Default Basic question about writing a differential equation related to finite element
RbBb is on a distinguished road
I'm writing a code to solve differential equations using a finite element method. I need to write a report about my activities. I know I should know this, but I'm getting confused about how to write a general differential equation in this situation. I have tried Google, but no luck. I would really appreciate some help. This is not a homework question; I'm an old fart and it has been a while since I did this stuff!
I know that when a variable is constant, it should go outside of the differential. For example, if k is constant, an equation should be written as q = k (dT/dx). But when using numerical methods, k might be constant within one time-step, but change for the next time step. So does this mean k needs to go inside the differential?
For example, in my code, there are several calculation steps in each time step. There is a calculation that changes k, then there are additional calculations to change other variables (all using the new k); q is calculated using the new k. Then we go to a new time-step and k changes again.
RbBb is offline   Reply With Quote
Old   April 10, 2014, 04:50
Marek Chodorski
marek_ac is on a distinguished road
Your equation should look like this:
http://feazone.org/readarticle.php?article_id=11
Regards,
Marek
PS Description is in polish
use google translator - the sense should be understandable - I hope
In your case T is temperature ( I guess ) in my S is concentration
marek_ac is offline   Reply With Quote
differences, equations, variables
How to Mix AIR and WATER Elvis1991 FLUENT 12 December 1, 2016 13:28
How can be calculate a surface integral in the finite element method? HectorRedal Main CFD Forum 3 March 13, 2015 09:25
Question about reference values --> Area (multi element wing) Zweeper FLUENT 7 March 28, 2010 12:29
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 23, 2005 00:49
question about energy equation zhou FLUENT 0 February 24, 2004 00:55
