Floworks -I decide what grid size/quality settings
Old   April 8, 2007, 14:29
Default Floworks -I decide what grid size/quality settings
trebor
Should I decide what grid size/quality settings I need based on looking at the final pressure on a surface that I am interested in, and run the simulation (Floworks) at quality 3, 4, 5, 6, 7, 8 (grid sizes) and then pick the fastest setting where the result is within a few percent of the quality-8 result?
Also if I do a time-dependent simulation for 0.001 seconds of physical time, I noticed that the number of 'travels' changes depending on the grid size. Why is that?
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
help on memory settings in TASCflow Dr C.Bhasker CFX 1 September 5, 2001 06:57
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 17:43
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
