Obtaining angular velocity given linear velocity and center of rotation 3D |
April 5, 2014, 01:21 |
TWB
Rep Power: 19 |
Supposed I'm given linear velocity and center of rotation in 3D. Can I obtain the angular velocity? I tried using: v = w x r v (1x3 vector) = A (3x3 matrix) * w (1x3 vector) then take the inverse of the 3x3 matrix A and w = inv A * v But the inverse of A gave an error. Why is this so? Are there other ways? I have the linear velocity and xyz coordinates of its location. Thanks. |
April 6, 2014, 12:05 |
venki
Rep Power: 15 |
please send the data , i will give the solution, u can do in excel itself
April 6, 2014, 12:08 |
TWB
Rep Power: 19 |
Hi venkateshaero,
What I mean is that supposed I know the linear velocity (e.g. = (2,5,-1) and center of rotation (e.g. = (5,3,-2). How can I obtain the angular velocity? How is it done in excel? Thanks. |
April 6, 2014, 15:16 |
Rep Power: 15 |
Hi quarkz,
It really looks like you have a 3D rotation which is a little bit more complicated. Just bear in mind that they behave like vectors if considered infinitesimal rotations. If it is the case, try out to do each one separatly and sum them together at the end. Regards, |
April 6, 2014, 17:00 |
venki
Rep Power: 15 |
I saw ur having problem in matrix conversion
April 7, 2014, 05:56 |
venki
Rep Power: 15 |
we can convert one co-ordinate to other co-ordinate locations, Linear velocity wont be three values
AMI Motions: Ramped Rotation Speeds and Nested Sliding Interfaces | lordvon | OpenFOAM Programming & Development | 1 | July 13, 2024 12:27 |
Functional relation between velocity at cell center and flux | fumiya | OpenFOAM | 0 | November 29, 2012 11:59 |
Accessing velocity at the cell center | alastormoody11 | STAR-CCM+ | 0 | February 9, 2011 00:12 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
