Pressure drag and friction drag
Old   April 4, 2014, 10:16
Question Pressure drag and friction drag
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
I'm wondering, for external flow, if there is no boundary layer separation happening, will pressure drag still exist?
Let's take airfoil as an example. If there is no boundary layer separation, will all airfoil drag be from friction drag?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   April 5, 2014, 19:05
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
A good part of your airfoil drag will be from the viscous component, yes.
As for the pressure component, you'll still have it regardless of your flow being separated or not as you'll still have a stagnation point on the leading edge which generates pressure drag along with the pressure gradient along your airfoil.
In theory, only a flat plate with no thickness will have only viscous drag.
Also, potential flow will result in no pressure drag (or no drag at all) for some bodies (as a 2D cylinder).
lovecraft22 is offline   Reply With Quote
Old   April 6, 2014, 00:32
Question
Anna Tian's Avatar
Meimei Wang
What do you mean by good part? Is that over 50% or not? Let's take airfoil NACA2412 as an example, at the AoA of 0 degree, will friction drag be the main part of the whole drag?
Best regards,
Meimei
Old   April 6, 2014, 10:43
Joachim
Joachim is on a distinguished road
You should have at least 90% viscous drag at 0 deg for an airfoil I guess (that will depend on the airfoil though).
If you really want to go in the details, your boundary layer growing on the airfoil will change the effective change of the airfoil (boundary layer displacement thickness), so that the Kutta condition will not be exactly satisfied. That typically results in some small additional pressure drag, even at low angles of attack.
If the wing is finite, you will also have some lift induced drag, which is basically pressure drag (influence of the tip vortex). This will depend mostly on the aspect ratio of your wing.
Joachim is offline   Reply With Quote
Pressure drag, friction drag and total drag? Cheng CFX 9 January 26, 2024 14:46
Relaltionship between pressure drop and drag force Li Main CFD Forum 5 March 4, 2017 17:04
Pressure Drag not calculated correctly in CFX-Post Andy CFX 5 August 2, 2006 13:06
Pressure drop and flow drag Li FLUENT 6 April 23, 2005 14:33
Drag on airfoil FP Mie FLUENT 2 February 1, 2001 11:21
