April 5, 2007, 10:30 |
3D NACA0012 with vortex generator
HI all, i m trying to model a 3D NACA0012 at angle of attack = 15deg with a forward wedge on it positioned just upstream the separation point.Unfortunately i haven t got good reults for convergence using high resolution.Then i have tryied blend factor 0.5, but the quality is not good.I can t see the development of the boundary layer at all, plus it looks like the separation is totally disappeared.It looks like the inflation layer are not visible in the post processed results.I m running now blend factor 0.75 and i have increased the infaltion layer thickness and number.What do you think i should do? Thank you for any advice.
Franny |
April 5, 2007, 10:31 |
Re: 3D NACA0012 with vortex generator
Factor to blend what ?
April 5, 2007, 10:43 |
Are you using a commerical software or home developed code.What kind of grid generation, numerical discretization ,boundary condition do you use ?.
Please be specific about all the details of your simulation.People cannot help you without knowing the details.How many points do you use in the boundary layer.A simple calculation of delta ~ 1/sqrt(Re),can be used to estimate the size and then you can determine the number of points to use according to your numerical scheme. |
April 10, 2007, 19:09 |
Thank you for your answer.First of all I would like to apologize for my bad english,it is probably not enough to write here and to be understood.Anyway, i really appreciate all the people that helped me already, and please do not be too sarcastic with others as one day you could need help as well.Thanks for now and KIND REGARDS. Franny
O-grid generator for NACA0012 | Prashanth | Main CFD Forum | 1 | October 30, 2009 00:11 |
NACA0012 gird generator | Prashanth | Main CFD Forum | 5 | May 1, 2009 05:20 |
Air-Jet Vortex Generator, request for some papers | ROOZBEH | FLUENT | 0 | July 12, 2008 11:28 |
Air-Jet Vortex Generator, request for some papers | ROOZBEH | Main CFD Forum | 0 | July 12, 2008 11:27 |
vortex generator | Pao | Main CFD Forum | 0 | June 3, 2003 10:25 |
