spurious oscillations and upwind-scheme
Old   March 27, 2007, 04:26
Default spurious oscillations and upwind-scheme
Chandra
hello,
I wrote my NS-equation solver and am testing it. (unsteady, 3D, incompressible, cylindrical co-ordinate). While solving the Energy equation, i found oscillations after using Central-Difference (CD) and no oscillations if Upwind-Scheme (UD). So, for the sake of better accuracy, I composed a hybrid scheme after mixing the two (25% UD, as follows) and found oscillations but very little amplitude as compared with CD scheme. Below is the hybrid scheme:
dT/dr = [dT/dr]_CD + ALPHA*(dx^2/2!)[d2T/dr2]_CD.
Here, "|ALPHA| = 1" for full upwind, "|ALPHA| = 0" for full central-difference and "0 < |ALPHA| < 1" for hybrid schemes. I used "|ALPHA| = 0.25".
To reduce the oscillation, one way is to increase |ALPHA|, say, to |ALPHA| = 0.5 and then do the computation.
What I want to know is: Can I expect BETTER accuracy if I use another scheme, say, Lax-Friedrichs with MUSCL reconstruction?? I saw very good results for shock-waves in this case.
In my case, for solution of the energy-equation, one wall is heated using a heater (20 kW/sq.m) and a water-jet is impinging normally on it. I don't know if this heated-wall boundary-condition is similar to a shock-like situation and whether the upwind-scheme is suitable for it. Based on your experience, please suggest me about this also.
Thank you very much,
regards, Chandra
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
When to use upwind or central differencing schemes? quarkz Main CFD Forum 6 August 19, 2011 04:24
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 12:08
SIMPLE and spurious oscillations Max Main CFD Forum 1 May 5, 2006 22:27
Spurious oscillations in porous media simulations David Boger Main CFD Forum 0 August 1, 2001 16:48
