moving coordinate system to center of 180 degree bend in flow 3d
Old   March 24, 2014, 12:39
Default moving coordinate system to center of 180 degree bend in flow 3d
Maryam Ak
maryamak is on a distinguished road
Hi dears
I'm working on my these that is about simulated a 180 degree bend (U-shape) via Flow 3d software. So I have a question about coordinate axes. I need to put the coordinate axes in center of the bend. But in flow-3d, coordinate axis is in the corner not in the center. I should use cylindrical coordinates to simulate and after that I have to use this data for drawing contour and stream line via Tecplot. So it's necessary to me that put coordinate axes in the center of the bend.
I search a lot about moving coordinate axes in flow-3d but couldn't find any text and help about it. Can you help me?
Thanks a lot for your attention.
maryamak is offline   Reply With Quote
coordinate axes, flow 3d, meshing 3d
[ANSYS Meshing] Inflation Layers around a 90 degree bend that is separated into multiple parts Kaaji1359 ANSYS Meshing & Geometry 2 August 18, 2013 19:57
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
180 degrees bend flow Tim Franke Main CFD Forum 0 February 1, 2000 08:28
[Q] Boundary conditions in Turbomachinery ghlee Main CFD Forum 3 July 23, 1999 18:05
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
