Commercial CFD Codes
Old   September 21, 1999, 02:53
Default Commercial CFD Codes
Praveen Chandrashekar
I have no experience with commercial CFD codes. I would be grateful if somebody can tell me briefly about the capabilities of some of these packages. I would be satisfied with some general statements.
Thank You
Old   September 21, 1999, 05:18
Default Re: Commercial CFD Codes
heinz
Ciao,
you might have a look at vendors homepages. Links to many of them you find in the list of sponsors for cfd-online.
If you have more specific questions you may ask again!
Heinz
Old   September 23, 1999, 23:21
cynthia
maybe you can find what you want at http://www.cd.co.uk
Old   September 24, 1999, 02:32
I was more interested to know the opinion of some of the users of these packages. Thanks anyway.
Old   September 28, 1999, 07:04
Luciana Araujo
We made a great experience with FLUENT 5 by modelling the radiation heta transfer. FLUENT 5 uses the Discrete-Ordinate-Method (DOM) which permits to modell semi-transparent walls. We used CFX 4 also to do this task, but without the transparent wall, which made all the model much complicated.
Old   September 28, 1999, 20:09
clifford bradford
Praveen, i think you'll find that the users who know CFD and communicate with their CFD vendors have good experiences using CFD. the ones who don't have bad experiences. also you should know what you want to do and choose the code that can do it best. also some users perticularly academic users don't get the customer support. this tends to make your productivity less because the customer support can help you a lot. i've been told by many on this group that not having customer support leads to them having to write lots of add on code. also you can see by the nuber of people asking questions about commercial codes here that it is important to have good customer service. hop that helps. cheers
Old   September 28, 1999, 20:24
Shi Xuefeng
I think all the commercial CFD Codes are almost the same. The sam model, the same solution method and so on. The important thing how much you can know it. That need help from the company.
Old   September 30, 1999, 13:07
Duane Baker
there is a great variety in commercial CFD codes and any investigation into what is available will bear this out. such variations are based on:
1. compressible/incompressible flow solution
2. pressure based/density-time marching
3. discrete formulation ie. FD,FV,FEM,spectral or combination of above
4. coupled/segrigated solver strategy for solution of "physical coupling"
5. linear solver ie. Gauss Sidel, Multigrid, SOR, etc.
6. physical models available ie. Multi-phase, radiation, turbulence, physical and thermodynamic property behaviour, combustion/reaction modelling
7...etc!
Lots of permutations and combinations of the above and that is only the solver issues NOT pre and post-processors.
Good Luck.................................Duane
Old   September 30, 1999, 13:18
Shi Xuefeng
Hi, Duane:
I think you just say what the commercial CFD COdes can do.
I have used the CFX and FLUENT. All most the commercial CFD codes can do what you mentioned.
Tired of employers focus on commercial code experience Steven P. Lounge 21 May 14, 2014 10:43
CFD JOBS and Expected Salary.... Noel Harrison Main CFD Forum 11 November 22, 2000 08:15
Customer Services Patrick Godon Main CFD Forum 32 August 23, 1999 07:55
solid kinetic theory wan xiaotao Main CFD Forum 6 August 10, 1999 19:43
modifying commercial codes Richard Carroni Main CFD Forum 1 October 15, 1998 07:38
