How to model VGs over a NACA0012
Old   March 24, 2007, 04:22
Default How to model VGs over a NACA0012
Franny
Hi all,i m trying to model a naca0012 with vortex generators on the upper surface and see how the separation is delayed respect to the configuration with no VGs.My idea is to re model the geometry with any cad software or in Ansys design modeler ,re-mesh it and re-run it once again. I was considering also to have a look at the function 'imprinting',because i ve heard that maybe it is possible to use applying the right boundary conditions. Anyone can tell his/her opinion about that?My doubt in re-mesh eveything for the 3D case (I ve done a 2D study already) can create some problems especially at the trailing edge. Thank you for now.
Franny
Old   March 24, 2007, 13:54
Default Re: How to model VGs over a NACA0012
Paolo Lampitella
A widely used way to model VGs in 3d is that of the source term in momentum equations. The most widely used model is that of Bender, Anderson and Yagle.
I worked on it in my thesis. you can find the abstract at the following link:
http://dma.ing.uniroma1.it/users/edr...2_Iannelli.pdf
It's not so much exaustive but it can give you some references. I also lost my unique copy of the paper of Bender, Anderson and Yagle and i'm now looking for it on the net but it seems to be a mission impossible so i can't send it to you.
Old   March 25, 2007, 06:05
Franny
Hi Paolo,thank you for your int.I ll try to see if i can manage.I m not sure yet,need to sit in front of the program.Im doing my thesys as well,and maybe i will ask you some references.From your link i suppose you are italian from Roma La Sapienza University right?I ve study there as well and now im getting my degree in UK.Ok,cheers for now.
Franny
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
Problem importing watertight model into CFX djk1301 ANSYS 3 February 1, 2011 23:04
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 20:13
NACA0012 Data as a function of Re for a VAWT model psd Main CFD Forum 1 July 31, 2009 23:04
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
