Turbine flow simulation data
Old   September 20, 1999, 22:41
Default Turbine flow simulation data
Mohan Varma
I am planning to simulate flow in low pressure axial flow turbines at high turbulence levels. I have gone through many publications, but I was not even able to get 3-D turbine blade profiles for flow simulation. If any one have any information about the references for the geometry profiles and simulation data, please let me know
Thanking you for your consideration
Old   September 22, 1999, 14:14
Default Re: Turbine flow simulation data
Rainer Kurz
There was a VKI (von Karman Institute, Belgium) Lecture series in 1989 that had some test case for 3-d flow. I can also recommend Fottner,L. ,'Test Cases for Computation of internal flows in Aero Engine Components', AGARD AR275,1990.
Old   September 28, 1999, 20:03
clifford bradford
as Rainer said the VKI has data on airfoil shapes etc for validation purposes, i suppose they can send you the info digitally if you ask nice. the ASME also had some 3-d geometries for a blind test case a couple years back. i guess it'd have the journal of turbomachinery
Old   October 18, 1999, 10:27
Ayyapillai Murali
Dear Mr.Varma,
We are also incidentally looking for similar data for modelling of low pressure axial steam turbine stages.
The only possible way is to contact a power utility /GT user ,obtain an used up/damaged blade from which you can generate the data by a CMM.
If I could succeed in getting the data, I will certainly share with you the same.
Thanking You
Ayyapillai Murali
Sliding mesh vs MRF in axial turbine simulation Vito FLUENT 3 December 21, 2011 05:57
wind turbine simulation moca CFX 1 July 25, 2009 07:48
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
flow in gas turbine Abdul Hafid Main CFD Forum 1 September 14, 1998 10:39
