March 20, 2014, 17:52 |
Rotor CFD Simulation
Kishen
Rep Power: 12 |
I am trying to model a Rotor in CFD (star-ccm+). My current model is massively under predicting lift. I am not entirely sure if this is because of the initial conditions or because the mesh is not fine enough. I have set up a moving reference frame for the rotor to which I have specified a rotational velocity. I am using the k-epsilon turbulence model for which I have calculated turbulence dissipation and kinetic energy. The Reynolds number of my rotor is based upon the rotor diameter and tip velocity and was found to be 65 million. I am also modelling it as steady state. I am expecting around 6000N of lift force but at the moment I am only achieving 1100N. I am aware that it is difficult to accurately model a Rotor but I am sure a lot of people have achieved it. I wanted some advice on what I could do to better simulate this. Thanks Kishen |
March 22, 2014, 14:40 |
Jon
Rep Power: 13 |
Have you looked at the post pro? Have the blades stalled?
March 23, 2014, 03:51 |
Kishen
Rep Power: 12 |
Yeah I've checked it and the blades haven't stalled. Also in reality my rotor isn't powered It is acting like a wind turbine. by applying a rotation to it I'm adding energy into the system rather than taking energy out. maybe I could apply a 1DOF to it or something. I have a feeling it's my model set up and initial conditions that are the problem.
I've created a much finer mesh and the load increased to 2000N. but I'm afraid that is the limit of my resources. The uni clusters won't be able to run anything better. Ps: I've heard of TotalSim. you guys do some cool stuff |
March 23, 2014, 04:54 |
Jon
Rep Power: 13 |
Thanks Kishen.
The relative velocity of the blade and fluid can be super critical to predicting the right forces. Have you done a speed sweep? You may only have to be 1% your blade or fluid speed to make up your deficit. |
March 23, 2014, 05:34 |
Kishen
Rep Power: 12 |
Actually now that you mention it, I have been thinking about the relative velocities and this may be where I am going wrong.
What do you mean by a speed sweep? I have assigned a rotation of 250rpm to the rotor. The free stream velocity is 30m/s. Btw I am using Star-ccm+. Best Wishes Kishen |
March 23, 2014, 06:28 |
Jon
Rep Power: 13 |
You can sweep either speed and it should have a similar effect.
I would tend to sweep the RPM. Maybe +/- 10%. You then can get a power curve. It may be that only a small different in RPM will get you to your 6000N. When compared blades/turbines/propellors this is often the best way to compare different options. Good luck. |
March 24, 2014, 14:03 |
Alfonso Jurado
Rep Power: 16 |
Hi Kishen, some questions
What are the reference values of lift you are using? Theory, Wind Tunnel? I manage years ago to obtain decent results (for lift) in 3 dimensional rotors for various angle of attack. I obtained these results in StarCCM+ with both Dynamic Meshing and MRF methods. Some comments about my experience: - First of all. I made sure I could obtain an almost perfect cl/cd curve for the 2D airfoil. - I made sure that my reference values was reliable and extrapolable to my case. - Those things may sound kind of obvious but I last longer in solve those than in obtain a good 3D simulation. Good luck |
cfd, rotor, star |
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 03:36 |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 13:02 |
