March 19, 2007, 10:20 |
Annular flow in pipe
Is there any general way to model the annular flow in a pipe?
Does anyone can give me some hint? Thanks a lot |
March 19, 2007, 10:25 |
Re: Annular flow in pipe
You mean using 2D-axisymmetric coordinates? You can solve for the third momentum equation, but taking into consideration that the annular pressure gradient is zero.
Can you give me some more details? |
March 19, 2007, 10:39 |
What is the third momentum equation?
March 21, 2007, 07:49 |
First is the axial velocity, second the radial and third the angular velocity. In axisymmetric flows the third is considered to be zero o just its pressure gradient to be zero.
March 21, 2007, 10:09 |
Yes I take an assumption that the flow is axisymmetric
February 10, 2012, 17:22 |
#6 | |
crane
Rep Power: 15 |
I found toroidal coordinate being used for annular curved pipe. In that article there were some references for annular pipe itself This is the name of article.look for it in science direct a numerical analysis of developing flow and heat transfer in a curved annular pipe hope this could help |
February 15, 2012, 14:01 |
Victor Azevedo
Rep Power: 16 |
I don't if this will help or not.
But, a good way to model is to separate the annular flow in 2 models: the core, and the film. You can run the film model and use its variables in the core model. |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 12, 2012 00:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 21:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 17:41 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 07:58 |
flow in pipe with momentum and energy source | Atit Koonsrisuk | CFX | 3 | March 29, 2005 17:58 |
