C-grid in Gambit
Old   September 20, 1999, 14:45
Default C-grid in Gambit
Gotfred Berntsen
Hi!
I am a graduate student, and I am currently working on a project that involves doing a 2D computation on a NACA 0015 hydrofoil.
Does anybody know how to do a C-grid in Gambit?
Old   September 21, 1999, 02:00
Default Re: C-grid in Gambit
John C. Chien
(1). C-grid is a structured mesh, which has a cut along the wake of the airfoil. (2). The indexing of the domain starts at the upper half of the exit and move upstream. It then wraps around the leading edge and follow the bottom surface of the airfoil back to the lower half of the exit. (In the wake region, the mesh must match along the cut.) (3). The C-grid can be generated by algebraic methods or numerical methods. I don't know whether Gambit can handle this or not. In addition, the points along the cut must match, that is two points at each location. For example, (i=1,j=1) is the same as (i=in, j=1) and so forth.
Old   September 21, 1999, 17:13
Poork Eda Peeg
If you have gambit and fluent you may want to use an unstructured mesh instead of a structured mesh. Since you are doing a simulation you should be able to pack a lot of cells at the trailing edge.
How to copy grid from GAMBIT Baheti FLUENT 3 June 18, 2013 13:50
grid for lance using Gambit star123 FLUENT 0 March 23, 2006 03:38
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 Isaac Manohar Ch. FLUENT 1 June 2, 2000 05:58
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 13:35
