Does using Parallel simulation improve Physics
Old   March 13, 2014, 09:17
Exclamation Does using Parallel simulation improve Physics
Peetak Mitra
peter.pan is on a distinguished road
I want to know for two cases using the same conditions, down to the RAM/per nodes, will using a parallel scheme improve the capture of the physics?
Suppose in Case 1 involves a million nodes and we run it serially using a 16 GB RAM system, now in Case 2 we run it in parallel using a four processor system each having 4GB RAM in such a way that the RAM/processor in both cases be same, 1 million nodes/16 GB RAM and 0.25 million nodes/4 GB RAM.
Which one would supposedly give me better results in terms of capturing physics better, ignoring the frailities of using a parallel code including ignoring Amdahl's Law.
peter.pan is offline   Reply With Quote
Old   March 13, 2014, 09:57
som87 is on a distinguished road
in short
improve computational potential==>yes
improve result/physics===>no
Best wishes,
Somdeb Bandopadhyay
som87 is offline   Reply With Quote
Old   March 14, 2014, 06:06
Peetak Mitra
Thanks Somdeb for your thoughts. But I thought a better computational resolution or better computational potential should yield better results? Or better computational results also depend on factors like more number of node points etc?
Old   March 14, 2014, 06:26
Let me elaborate on :
Yes, better computational resolution indeed yields better result. But computational resolution is not something which depends on our computational power.
Say you are doing DNS of 3d lid driven cavity with 200x200x200 mesh.
How resolve our computation'll be, depends alot on the mesh i.e. at how many nodes you have the solution (the discrete one).
Now returning to your point, with more computational power (i.e. parallel) we can deal with more number of mesh which'll eventually provide a higher level of "resolution" in our result. But the "better" result is due to more "refined discretization" not 'cause of your 'computational power'
-----the end from my part-----
Best wishes,
Somdeb Bandopadhyay
Old   March 14, 2014, 06:29
Peetak Mitra
Thanks Somdeb, that makes perfect sense. Appreciate your reply
hpc, parallel computation, serial
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
free surface simulation with parallel caculation? rabbitmelon CFX 1 July 27, 2013 08:13
help with command line in parallel simulation ernest STAR-CCM+ 8 August 17, 2011 06:02
Improve Mesh quality - airfoil simulation Lukas84 STAR-CCM+ 4 July 6, 2010 11:07
Parallel Deforming Mesh Simulation Tristan CFX 1 January 28, 2009 18:59
