Nozzles: Modeling the Discharge Coefficient
Old   March 12, 2014, 12:41
Default Nozzles: Modeling the Discharge Coefficient
Liam
LiamH is on a distinguished road
Send a message via Skype™ to LiamH
Hey Guys,
This is my first post on the forum but I am a regular reader since I started doing CFD modeling with Fluent. So I need help right now since I have been banging my head against the wall trying to figure this problem I have out.
My problem is that when I am modeling the discharge coefficient of a nozzle, I am getting different values for the discharge coefficient depending on where I take the pressure readings. I am taking presssure readings at the inlet, throat, outlet and sometimes farther downstream/upstream of the nozzle. These values sometimes will go above 1 which seems to be allright when I am also looking through a fluids textbook.
However, when I wish to find the pressure loss coefficient from this value, I am skeptical on the results. I have read many papers where they take the discharge coefficient and say that the pressure loss coefficient is (1/C^2) which can be done by rearranging the equation. But in doing this, I am getting values BELOW 1 and according to theory involving the pressure loss coefficient (or Euler Number), this cannot go below unity. I need help understanding where I am going wrong.
-Am I taking pressure readings in the nozzle at wrong locations?
-What if I am determining the pressure loss coefficient in a simple system rather then a nozzle? Where would I take the pressure readings for that?
-Is the "Euler Number" used to measure the pressure loss coefficient in any system?
http://en.wikipedia.org/wiki/Euler_number_(physics)
Any help will be appreciated! Thanks!
LiamH is offline   Reply With Quote
discharge coefficient, euler number, nozzle, pressure loss coefficient
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
discharge coefficient abudaniell FLUENT 3 April 21, 2013 09:31
Discharge coefficient in function of pressure ratio Roland R CFX 1 September 24, 2012 22:58
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
coefficient of discharge MADANI SYED Siemens 1 January 4, 2006 05:46
