September 19, 1999, 19:29 |
A problem about setting boundary conditions
Here I have a question associated with setting boundary conditions. Currently, I am using Gila(a finite element codes0 to solve a 3-D problem. Gila only provides two options to set the boundary conditions: natural and prescribed. For natural conditions, one doesn't need input anything in the input data file. For prescribed conditions, one need to input the specific values for the boundary conditions. When my boundaries are normal or paralell to the selected coordiantes, there are no problems to set the boundary conditions. However, there is a plane which does not satisfy these conditions in my problem. This plane is a slip plane which means there is no mass crossing this plane and the derivative of the velocity in the tangent direction with respect to the unit vector normal to this plane is also zero. My problem is: how can I set boundary conditions for this plane? There is no way to modify the Gila codes. In one case, I just assumed the natural conditions for this plane. But the visualized results turned out to be incorrect. I was really confused by this problem. I'll appreciate if any people can give me some advices. |
Boundary conditions in combustion Problem | jose_rodrig | OpenFOAM | 3 | February 2, 2013 11:26 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Fluent boundary conditions problem | bobo | FLUENT | 2 | July 3, 2009 07:28 |
Problem setting boundary condition from file | Antonis | CFX | 1 | September 11, 2006 17:53 |
Boundary conditions problem | philip | FLUENT | 6 | June 10, 2005 14:00 |
