Vortex Rings
Old   August 24, 1998, 03:33
Default Vortex Rings
Ozgur M Polat
Hi! I am Masters by research student and I am looking for the right software which I could use for analysing and simulating vortex rings.
Old   August 24, 1998, 05:01
Default Re: Vortex Rings
Fabien Coppens
Hi. In your case, the ideal software would be a DNS or LES code in cylindrical coordinates. Paolo Orlandi from University La Sapienza in Rome has done a lot of work on this type of flow. Check out some of his publications. Good luck.
Old   August 26, 1998, 08:43
Joern Beilke
At the last StarCD users meeting a work from Dr. Menno Eisenga was presented, where he used StarCD for that problem. You can find some information on
http://tnj.phys.tue.nl/work/rings.html or you can ask Menno (menno@tng.phys.tue.nl) for more help.
Hope this helps,
Joern (http://www.beilke-cfd.de)
Old   August 31, 1998, 15:50
Adrin Gharakhani
Actually, depending on the particular type of problem you wish to analyze, vortex element or filament methods are the most ideal method for solving vortex ring problems (DNS or LES)
By construction they satisfy the far-field boundary conditions and you need to discretize only the vortex ring (in the traditional CFD methods you'll have to discretize a much larger flow domain)
There are presently no commercial vortex element software, to my knowledge, although my company is involved in developing such a code.
Old   October 9, 1998, 14:24
Eric Lam
Hi
I don't know if I can help. I have seen that formation in a research experiment and also got the same result in the 3-D simulations. But I have no idea if we're talking the same. Pls. write more about it.
Eric.
Old   October 16, 1998, 00:29
Ozgur Polat
I have red many research articles on the characteristics of vortex rings especially the formation of vortex rings at the edge of circular tubes and the generation methods. But there is only one research (I have seen so far) in which the formation of vortex rings in air is investigated. Is there someone who studied the formation of vortex ring in air and who used water mist to generate vortex rings in air?
Vortex Rings in FLUENT? nha1g08 ANSYS 7 May 18, 2013 05:34
creating vortex core line aay023 Main CFD Forum 0 September 15, 2010 22:49
Programming own CFD, noone supports vortex rings? DanFrederiksen Main CFD Forum 18 September 4, 2010 03:20
Panels vs Vortex Rings Gerrit Main CFD Forum 3 August 3, 2009 05:19
turbulent scales of forced vortex and free vortex lcw Main CFD Forum 3 September 1, 2005 14:40
