Question about the Wall-reflection term in RSM
Old   March 3, 2007, 06:31
Default Question about the Wall-reflection term in RSM
Lucy
Hi, every one
I have a question about the wall-reflection term when using the Reynolds Stress models RSM .
When simulating turbulent flow in complex geometry with the RSM, a wall-reflection correction is needed for the pressure-strain term. There is a parameter △y,denoting the normal distance to the wall. I am confused that when there are several walls in the geometry, how many wall-reflection terms will be? Does every wall corresponds a wall-reflection term? For example ,when I calculate the turbulent flow past a backward-facing step, how do I calculate the wall-reflection term near the step corner?
Thanks in advance.
Best Regards
Lucy
Question about modeling an elastic wall in Fluent Mosheraa FLUENT 2 June 24, 2011 19:47
one question about nearest wall distance Hellen Main CFD Forum 1 July 20, 2005 03:32
Does RSM use wall function? Sam Main CFD Forum 4 March 3, 2005 00:58
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 05:29
Wall reflection terms Astrid FLUENT 0 March 16, 2002 17:31
