the role of speed of sound in pressure based solver
Old   March 3, 2014, 03:39
Question the role of speed of sound in pressure based solver
Leon Chen
759599290 is on a distinguished road
Hi everyone,
Recently i am conducting a simulation of water flow in porous media using FLUENT. It is known that the density of water changes with temperature and pressure, so I programmed a udf to adjust the properties of water according to IAPWS-IF97. here I am puzzled by a problem and hope for your help:
when I defined the speed of sound of the materials, i.e. water, the simulation can run well, while if I set it to none, then back flow occurs and the calculation break down only after three steps. And if I don't invoke pressure, that is to say neglect the influnce of pressure, then no matter what value the speed of sound is, the calculation can run well. I use pressure-based solver.
I searched a lot data and could not found how the speed of sound can lead to such a huge difference in this simulation. Hope for your help.
759599290 is offline   Reply With Quote
density-variable, fluent, pressure-based solver, speed of sound
Pressure based and Density based Solver taekyu8 FLUENT 0 January 28, 2013 12:05
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 13:45
Solver and density function for high speed vapour christian OpenFOAM Running, Solving & CFD 17 April 12, 2007 03:41
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
