Flow near sharp corners
Old   February 21, 2007, 00:29
Default Flow near sharp corners
Harish
I need some ideas or references on how to treat sharp corners like the ones we come across in lid driven cavity flow or flow over a flatplate.
Old   February 21, 2007, 01:41
Default Re: Flow near sharp corners
diaw (Des_Aubery)
Increase mesh density in those regions.
Try & maintain fairly evenly-proportioned elements - ie. tending towards square (if 4 sided), or isosceles (if 3 sided).
Make sure your mesh is well blended back into regions of lower mesh density.
Most importantly - time your dynamics around these regions.
See if it is possible to use higher-order elements in those corners, or over the whole mesh. P2 is good.
desA
Old   February 21, 2007, 09:57
Harish
I do not use unstructured grid or a finite volume solver.I use simple finite differences on a structured grid.I tried to maintain a the spacing pretty much constant in both directions close to the leading edge and it seems to work.
Thanks
Old   February 21, 2007, 11:00
mettler
using the finite difference there really isnt much you can do except, as diaw said, make your spacing very small. But, that will lead to a lot of computations. The trick is the boundary conditions at the corner. Also, you should get Ghia's paper and compare results. Gupta also has a good paper on it. That will, more or less, let you know if you are on the right track. Depending on your Re number you will get recirculation zones in the corners.
Old   February 21, 2007, 22:55
desA
It's been a while since I last used FD, but, I would wonder if you could think of using a higher order stencil in these corner regions? Perhaps you could run up your system matrix as usual & then bring in the high-order stencil?
desA
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 13:14
Help! Supersonic/hypersonic flow over sharp wedge/cone, detached shock jwtan FLUENT 0 March 25, 2009 06:02
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 10:49
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
