power input / output help
Old   February 16, 2007, 02:22
Default power input / output help
zonexo
I would like to find out how to calculate power input / output for a moving airfoil.
p(in) should be thrust * vel. -> should be quite certain
p_in = - Lift (L)(t)*dy/dt - Moment (M)(t)*d(theta)/dt ->
I got this from some papers, which is amount of energy imparted to the airfoil for it to overcome the fluid force.However, the case considered was for an airfoil moving up/down and pitching. What I'd like to know is if the airfoil is also moving sideways (left,right), will I have to add - Drag (D)(t)*dx/dt?
thanks alot!
Transfer output data as input for second calculation mannobot Main CFD Forum 3 December 7, 2018 10:37
airfoil design- input x and CP. output y OR input Qspec gcjin07 Main CFD Forum 3 April 28, 2011 18:01
Defining output as input for second calculation mannobot FLUENT 1 June 2, 2010 05:20
How to compute power output using VBM? Lorraine FLUENT 0 December 31, 2008 03:25
Output power from simulation JSM FLUENT 0 November 27, 2008 07:04
