4th order discretization of 2nd order difference
Old   February 11, 2007, 04:01
Default 4th order discretization of 2nd order difference
dusky.He
Does anyone can tell me the form of 4th-order discretization of 2-order difference in cylindrical coordinate.
In Cartesian coordinate, it is (-F(i-2)+16F(i-1)-30F(i)+16F(i+1)-F(i+2))/(12*dx)
Old   February 12, 2007, 01:36
Default Re: 4th order discretization of 2nd order differen
Harish
If you have mathematica/maple/maxima you can find the coefficients using it.Also look for the paper on compact scheme by sanjeev lele ( JCP 1992),it should give you the required finite difference discretization.
Old   February 14, 2007, 05:16
Chandra
discretization is independent of co-ordinate system [d2u/dx2 or d2u/dr2 are same]. If, whatever u have wrote, is correct in Cartesian co-ordinate, it is correct in Cylindrical co-ordinate as well. So, enjoy!! you already have what r u looking for
What changes with change in co-ordinate system is terms itself, not the way it is discretized.
hope it helps.
Old   February 14, 2007, 09:00
qunwuhe
You are right, but I want to discretize the Lapace of Phi in cylindrical coordinate. So the divergence of a gradient in cylindrical is different from the one in Cartetian coordinate.
Limiters for 2nd order solvers Heinz Wilkening Main CFD Forum 1 March 14, 2013 04:40
2nd order and Turbulent-viscosity ratio error freekeer FLUENT 3 October 5, 2010 06:41
2nd order discretization Pavel O FLUENT 0 September 28, 2009 10:15
4th order schemes in channelOodles maka OpenFOAM Bugs 9 January 19, 2009 12:58
High order compact finite difference schemes Mikhail Main CFD Forum 6 August 5, 2003 11:36
