Turbulent flow in Turbine Blade Cooling Passage.
Old   February 9, 2014, 02:34
Default Turbulent flow in Turbine Blade Cooling Passage.
avinashjagdale
avinashjagdale is on a distinguished road
Which RANS model will be most suitable to model Constant temp.(room temp) turbulent air flow inside the Cooling Passages of turbine blade(stationary)
Thermal effect and rotational effects not considered, as the experimental values I have are of blade model stationary and at room temp.
the geometry is similar to one below ->
http://www.ligrani.com/Research/Grou...g-1.jpghttp://
avinashjagdale is offline   Reply With Quote
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 08:45
film cooling in gas turbine blade ponnusamy Main CFD Forum 5 January 25, 2011 17:24
how to do this blade passage flow analysis ? manish CFX 2 January 16, 2006 04:58
Turbulence model for turbine blade cooling CFD Student FLUENT 0 December 20, 2004 09:30
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
