Turbo mode question
Old   February 8, 2014, 15:47
Default Turbo mode question
lauda
lauda is on a distinguished road
I run a single stage turbine case with periodic boundaries. Unfortunately I couldn't use turbo grid for the mesh generation, which I think helps the post processing… I would need to extract the outlet flow features (tot temperature and flow direction) to be used as inlet conditions for a diffuser. However since I can't treat the diffuser with periodic or symmetry boundaries I need to create a full annulus outlet solution of the turbine that would match the inlet section (a circle) of the diffuser. I've been trying in CFD-post (turbo mode) but I didn't manage so far. Could you help me in that? or could you suggest a tutorial for such purpose? thanks
lauda is offline   Reply With Quote
cfx-post
Save images using Fluent in batch processing mode dixitked FLUENT 8 August 29, 2019 13:25
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 13:11
Batch mode question cfdengineer CFX 3 January 16, 2016 21:05
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 09:00
Grid Check Fails in Parallel Processing Mode askance Main CFD Forum 0 October 20, 2010 11:11
