External Flow Aerodynamic Tanker Vehicle
Old   February 3, 2014, 01:23
Exclamation External Flow Aerodynamic Tanker Vehicle
rzhang is on a distinguished road
I am having trouble selecting the right mesh for what I am doing:
External Flow Aerodynamic Air over Vehicle Tanker
It is a complex component which I have tried to simplify.
I am planning on running a turbulent model (likely SST), however am not sure what mesh properties to use to generate a flow of decent accuracy.
Usually I will insert an inflation around the whole body and select a face sizing. But I get the following warning:
"Pre-inflation layer generation are ignored for the following faces"
And so when I generate the mesh, the inflation layers are not present.
Is adding inflation layer and face sizing sufficient properties for mesh generation?
Is this to do with the CAD geometry discrepancies? What is the best way to solve this?
Hope someone can help.
Ive attached picture of the CAD model, and an inflation preview with green highlight of one "problematic geometry" face.
Thanks in advance!
rzhang is offline   Reply With Quote
multiphase-eulerian compressible external flow adhivenugopalan FLUENT 0 July 16, 2013 06:52
How do I select solver options for external flow over an aircraft by fluent? hadieliasi FLUENT 5 May 2, 2011 04:54
Modeling internal and external flow for a nozzle smschnob Main CFD Forum 1 November 11, 2010 18:12
Best settings for solar car external flow problems kdrbrk Main CFD Forum 0 July 16, 2010 03:18
External flow field. Moon FLUENT 3 March 5, 2003 11:32
