Temperature and heat flux wall boundary condition |
February 1, 2014, 04:32 |
Hamid
Rep Power: 16 |
Dear All, In my model, I have a coil which transfers the heat flux 5000 w/m2 to gasoline. I set the wall of coil boundary condition by this heat flux. After convergence the model, I checked the surface temperature of the coil. It was 1000 K. But In real, the surface temperature of the coils shouldn't exceed 400 K. How can I control the temperature and heat flux of the coil? Any help would be appreciated Hamid
February 1, 2014, 14:00 |
Hamid Zoka
Rep Power: 19 |
where does the 5000 w/m2 come from?
It seems that heat flux is highly over predicted. could you give an image of your computation domain plus boundaries defined? |
February 2, 2014, 01:05 |
#3 | |
Hamid
Rep Power: 16 |
Dear Hamidzoka, I have a gasoline tank with 46 m diameter and 13 m height. two row of coils are located near the bottom of the tank. the initial temperature of gasoline is -5 C. By this Coils it should be heated to 9 C. the coils flux is come from steam which is flows through the inner side of the coils. the coils length is 200 m with spiral shape. the coils diameter is 115 mm. in fact the gasoline is heated by free convection. the flow regime is turbulent. (Ra > 10^9) I have set fixed temperature of ambient for B.C of the tank walls (side walls, bottom wall and top wall). Sincerely Hamid |
February 22, 2014, 22:10 |
Value of Q
Abhijeet Shrawage
Rep Power: 14 |
As the previous poster suggested...maybe try recalculating the value of the heat flux applied.
you have dT of 14C. You know the surface area of the heat source (heating coil). Use the simple formula. q=*Cp*T If Cp is varying, then substitute Cp with dH; the change in enthalpy of gasoline at -5C and 14C. If again you get the same answer, then try double checking if you have put the right thermophysical properties of Gasoline in your FLUENT material database. Things like low Cp or high thermal conductivity can be the cause of this as well. Best of Luck. Abhijeet |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
