hesam
Rep Power: 12 ![]() |
Hello everyone, I’d like to investigate nanofluid turbulent flows inside tubes.
1) Are the standard or scalable turbulence wall functions suitable for nanofluid flows? If they are not, what do you suggest I do? 2) Can thermophoretic force be neglected? Because the temperature gradient of the silver nanoparticles (with high thermal conductivity) is very little. 3) Can Brownian motion be neglected? Because of the fact that the diffusion speed of the Kolmogorov turbulence is much faster than that of the Brownian motion? Any help would be appreciated. Thanks. |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
what about the Kolmogorov length in your problem? I am not sure you can have a real turbulent field due to the law scales in microfluidic...
Required artilcles in Turbulent Flows !Urgent! | amirbabak1979 | Main CFD Forum | 0 | October 26, 2009 13:03 |
Non-Newtonaian Turbulent Flows | meroney | FLUENT | 0 | August 30, 2009 15:46 |
Mesh Construction near wall boundaries in turbulent flows | ageorg | FLUENT | 0 | July 8, 2009 06:36 |
calculating recirculating turbulent flows with k-e | Abhijeet Vaidya | Main CFD Forum | 10 | November 18, 2002 08:21 |
Flotran problems with compressible turbulent flows | Ross | Main CFD Forum | 1 | September 27, 2002 13:08 |
