CFD software!
Old   September 15, 1999, 15:25
Default CFD software!
J. Pinto
Dear all,
I know that CFD is a powerful tool to simulate any physical problem. I want to draw stream lines around spheres that are placed equally spaced into a incompresible laminar fluid. Also I want to evaluate the velocity component at any locations? Could you please suggest me free CFD software or very low cost? I'm really appreciate your help...thanks.
Old   September 16, 1999, 17:16
Default Re: CFD software!
Demselles Hollowajiawoak
I have heard of a software called FlowSim 2d that may be of some help. I will try to talk to the guy who wrote it to see if he can assist you!
Regards Demeselles Schiafenillia Hollowajiwoak
Old   September 17, 1999, 15:18
clifford bradford
if have access to a mac you can also try Quick 'n'Simple which is available at http://icemcfd.com/cfd/CFD_codes_p.html#QnS it uses the SIMPLE pressure based method and QUICK differencing and is quite easy to use
Old   September 28, 1999, 14:01
J. Pinto
I download quick'n'simple. How can I draw spheres or circles into the grid?.
Old   September 28, 1999, 19:09
clifford bradford
i haven't used the code in years. perhaps you can contact the author of the code
CFD Salary CFD Main CFD Forum 17 January 3, 2017 18:09
CFD Software Recommendation 1150GSA Main CFD Forum 3 September 2, 2009 16:46
What is the optimal (economically and user friendly) CFD software for my application? Rame Main CFD Forum 0 August 10, 2009 06:30
ASME CFD Symposium - Call for Papers Chris Kleijn Main CFD Forum 0 September 25, 2001 11:17
ASME CFD Symposium Chris Kleijn Main CFD Forum 0 August 22, 2001 07:41
