How to add inflow data the using frozen turbulence hypothesis
Old   January 29, 2014, 09:18
Default How to add inflow data the using frozen turbulence hypothesis
hiter is on a distinguished road
I have one simple qestion that is how to use Taylor’s frozen turbulence hypothesis in DNS similation. In many references, they all simply say 'Imposed'.
For instance, we have already obtained the HIT external turbulence.
u_et(t,y,z). t is the time step, and y, z denote vertical and tranvese directions.
At the inlet X=0, the instantoust velocity u(0, y, z) = u_et(0, y, z) + U0(y, z). U0 is the given mean inlet velocity.
At this step, everything is O.K.
In our DNS, in x direction the nonlinear terms are discretized by the fourth-order central difference scheme, and visoucous term by eighth-order central compact scheme.
We assume that we set the caculation domain point in X direction N1, NX.
So the boudary condion reqired velocity at point N-3, N-2, N-1. Howver, we only have the u_et(t,y,z) at one time shot.
Also, another problem, maybe less that puzzing. We use the fractal step method, at every substep, is it reason to remain the u_et unchanged.
Thanks in advance.
hiter is offline   Reply With Quote
taylor’s frozen
Add additional scalar to turbulence model john_w OpenFOAM 1 December 23, 2010 13:45
how to add turbulence HaKu Main CFD Forum 0 September 17, 2010 12:30
How to add turbulence purtubation in the middle of the computational domain? ivanbuz FLUENT 1 August 27, 2009 02:14
Tecplot. add experimental data into a mesh Alejandro FLUENT 0 December 10, 2008 08:08
Text input commands to add data points Kathryn FLUENT 0 November 5, 2007 18:38
