Regarding the coincidence of stream line contours and stream traces |
January 27, 2014, 09:19 |
Shatrughan Jaiswal
Rep Power: 12 |
Hi all,
I am doing a problem related to centrifugal effect with cavity rotation. when i am plotting the results in the Tecplot360 2009, the stream traces and streamline contours are not coinciding, actually both must coincide. If this problem can be solved then please suggest me what to do, if not then please tell me the reasons behind this. If any one can solve the problem please reply me, i will be grateful to you. Thanks in advance... |
January 27, 2014, 09:34 |
Alex
Rep Power: 49 |
As far as I know, a stream tracer is basically a particle that is subject to inertial effects.
Consequently, ts trace only coincides with the streamline when its mass is zero. |
January 27, 2014, 14:59 |
Filippo Maria Denaro
Rep Power: 73 |
[OpenFOAM] How to make boundaries contours visible when using stream tracer | A.A. | ParaView | 0 | October 10, 2012 08:34 |
how to display the stream line | ice | FLUENT | 1 | February 21, 2007 09:54 |
stream contours in 3D geometry | satya | FLUENT | 5 | September 28, 2003 06:06 |
