How about Hyperbolic Conservation Laws in Canada?
Old   January 30, 2007, 10:21
Default How about Hyperbolic Conservation Laws in Canada?
morxio
Hi,everybody here! How about the study of hyperbolic conservation laws in Canada? What university in canada is more famous at the investigation of hyperbolic conservation laws?
Extremly thank you for your reading... I'm eger for your answer or suggestion.
Old   January 30, 2007, 12:52
Default Re: How about Hyperbolic Conservation Laws in Cana
TG
I thought they repealed those laws in Canada
Old   January 31, 2007, 00:29
morxio
Anyway,thanks for your answer!
Well, Hyperbolic Conservation Laws are a area of fluid dynamics.
For example , Eular equations and N-S equations are all hyperbolic onservation law equations .
Conservation laws is mass conservation law , momentum conservation law and energy conservation law in physics.
So, they are the basis of the study for gas dynamics and other fluid kinetics.
I want study abroad. And I want to continue my major. Thus, I expect to know which universities have such program for Ph.D .
Thanks in advance.
Old   January 31, 2007, 05:29
Tom
"For example , Eular equations and N-S equations are all hyperbolic onservation law equations ."
Not quite - The N-S equations are parabolic not hyperbolic (the only real characteristic is time).
Old   January 31, 2007, 08:21
Jose
"Not quite - The N-S equations are parabolic not hyperbolic (the only real characteristic is time). "
Not quite - The N-S equations are mixed hyperbolic/elliptic, but they can be parabolized.
Old   January 31, 2007, 09:24
anon
Nope, Tom was correct. The N-S are indeed formally parabolic in nature. The selection of certain coefficients may bias the results towards an asymptotic solution, but the equations remain formally parabolic.
You can test this using Anderson's approach, for instance.
Old   January 31, 2007, 09:27
Tom
Look up your definitions for the classification of pdes. The NS equations ARE parabolic.
Old   January 31, 2007, 18:42
Ananda Himansu
the character of the (time-dependent) N-S equations probably depends on whether you refer to the compressible or the incompressible sets
Old   February 1, 2007, 06:33
Tom
The viscous/dissipation terms ensures both cases are parabolic (the thermodynamic arrow of time)
Old   February 1, 2007, 23:34
Angen
I do not know any major center for study of Hyperbolic Conservation Laws in Canada. However, I do know one very close to Canadian border. It is Applied Mathematics at the University of Washington in Seattle. Less than 200 km from Vancouver.
Angen
Old   February 2, 2007, 03:58
  #11
Harish
I'm not sure if a lot of work has been done on hyperbolic conservation laws but university of toronto is a bit close to your requirements.
Old   February 2, 2007, 11:42
  #12
unimportant
Check David Zingg's group at UTIAS (http://goldfinger.utias.utoronto.ca/~dwz/). They don't do conservation laws exclusively but they do work on compressible flow problems (inviscid and viscous). Unlike Le Veque at Washington, they don't have research concerning all sorts of hyperbolic laws, only compressible flows. Maybe he will be interested in student working on other things not traditionally done by his group. Good luck.
Old   February 2, 2007, 11:43
  #13
morxio
Thank you very much for your warm advance ! I'll go to the website of University of Toronto.
Old   February 2, 2007, 12:04
  #14
morxio
I extremely appreciate your help!
Are you studing in this area? or related?
Old   February 2, 2007, 14:36
  #15
unimportant
I have spent some time at UTIAS many years ago and I am no longer in the area. However, I maintain some links with several Canadian universities and from time to time I visit them and do public lecture on my research. I think you will find UTIAS to be a very good place with many qualified researchers and good links to industry. Good luck in your research plans.
Fifth order anti diffusive scheme for 1D hyperbolic heat transfer areffallah Main CFD Forum 0 November 3, 2010 05:48
conservation laws in a domain with a moving boundary ANPDEstudent Main CFD Forum 0 July 19, 2010 21:59
lost of mass conservation jjchristophe FLUENT 0 June 18, 2010 06:44
conservation laws shuo Main CFD Forum 0 June 14, 2008 23:15
2-D linear hyperbolic system Rits Main CFD Forum 4 December 19, 2005 00:56
