Need some support in modelling a cylinder
Old   January 23, 2014, 06:17
Default Need some support in modelling a cylinder
naresh007 is on a distinguished road
Hi friends,
I am unable to design a cylinder in gambit. I am blocked with my project. Can kindly someone help me please. Kindly check for the attachment of what actually I am trying do.
Project details follows
Fuel Spray In Engine Cylinder
To study and compare the spray length, cone angle of the spray and droplet size inside the cylinder of petrodiesel and biodiesel.
. 3 orifices at 120° each
. At the end of compression,
Air pressure = 30-40 bar at 250° C
Fuel pressure = 250 bar
Arrangement : A cylinder arrangement of a diesel engine with the two valves in the closed position. An injector is placed in the middle vertically, the nozzle tip has 3 orifices placed at 120° each. Orifice dia being 0.6mm.
All the dimensions of the cylinder arrangement to be taken according to any specific standard.
Thank you.
naresh007 is offline   Reply With Quote
Old   January 23, 2014, 12:22
Default support modeling a cyinder
Amrinder Singh
amrinder703 is on a distinguished road
Hello Naresh
do you want to model with valves?, It will be complex with , I would suggest model only cylinder. Its easy to model cylinder with hexa msehing in ansys icem.
True grid can also be used.
thanks
Amrinder Singh
amrinder703 is offline   Reply With Quote
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 11:42
Cylinder moving in fluid,Solution diverging arun7328 STAR-CCM+ 5 February 27, 2013 15:28
Port flow modelling in FLUENT zeppelin101 FLUENT 0 January 14, 2011 11:17
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
