isothermal medium
Old   January 22, 2014, 06:42
Default isothermal medium
myaccount is on a distinguished road
I am studying the heat transfer rate within an isothermal medium which is not moving(still) and it s at temp T1. The medium is confined within two large black isothermal walls of temp T2.
If we have to specify a wall as isothermAL, we can just give the value of the temperature in boundary conditions>>edit>>thermal >>thermal conditions>>temperature....
Am i right??
And if we want to specify a medium (fluid /solid) as isothermal, how to give a specified temperature for that? Because in boundary conditions panel, for solid or fluid, we can only edit the name and nothing else.. pls tell me how to specify a still medium as isothermal... ?? Do we have to specify it in reference values section ?? or do we have to give it under cell zone conditions>>edit>>Fixed values>>Temperature ???
I tried it with fixed value once an as i am wrking in radiation heat transfer problems, i dont think I am right..
myaccount is offline   Reply With Quote
Turbulent flow in porous medium Chander CFX 4 January 17, 2017 10:50
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 07:32
Lack of local thermal equilibrium in porous medium Chander CFX 4 March 4, 2012 05:07
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? Chander CFX 3 November 28, 2011 15:26
porous medium and reactions Valeria FLUENT 1 July 10, 2009 04:58
