why this type of bc are there?
Old   January 26, 2007, 10:33
Default why this type of bc are there?
kunder
I have query that, why for comp flow we are using mass flow at inlet and for external flow we can use velo at inlet? pls reply Thanks
Old   January 26, 2007, 14:12
Default Re: why this type of bc are there?
ag
Maybe because in a steady flow computation you eventually want to have mass in = mass out for the internal case, and for an external flow case we don't have that as a hard and fast restriction (i.e. mass can leave along multiple parts of the farfield boundary), and the flow at the boundary can adjust to account for global conservation.
Old   January 26, 2007, 14:51
ag
Also note that typically these are among the easiest and most natural quantities to define at those particular boundaries from a problem definition perspective.
second order schemes marine OpenFOAM 67 April 11, 2022 19:19
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
