January 15, 2014, 20:58 |
Ansys Static Structural
Arief
Rep Power: 13 |
Dear All,
What all you know the function command "fixed support & frictional support" to analysis system ? And I have a model, I give force 6 Tonnage in surface color red. So do you think, where I should give the command "fixed support & frictional support" in which the parts on this model ? Bottom view & Side view If all you know the answer, please for an explanation... Thank's |
[ANSYS Meshing] importing a cfd in ansys static structural | nauman55 | ANSYS Meshing & Geometry | 0 | July 23, 2013 09:22 |
Runtime difference between Ansys Static Structural and Transient Analyses | Danito | ANSYS | 0 | June 26, 2013 15:10 |
Static structural analysis using ANSYS Mechanical APDL | sds10 | ANSYS | 1 | June 23, 2012 01:25 |
Import transient cfx-results for static structural analysis in Ansys WB 13 | Colt Seavers | ANSYS | 1 | August 11, 2011 07:01 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 06:08 |
