Two-phase flow on porous media - Validation of 1D flow
Old   January 2, 2014, 03:05
Exclamation Two-phase flow on porous media - Validation of 1D flow
Jhabriel Varela
jhabriel is on a distinguished road
Hello, I'm having some problems validating a numerical simulation (ImPES [Implicit Pressure Explicit Saturation]) with the Buckley-Leverett (analytical) model. As you know, the Buckley-Leverett model only needs a constant inlet flow of a phase, on the other hand the ImPES method only deals with pressures values. How should I treat the boundary conditions in the ImPES method in order to compare the both cases?. I tried setting a fixed total Darcy velocity, but, in order to conservate the mass, in theory, the total velocity through each faces should be the same, so I would have the same velocity on all the time levels, and the saturation front won't be able to propagate.
Thanks for any idea.
Jhabriel Varela
National University of Asuncion
jhabriel@gmail.com
jhabriel is offline   Reply With Quote
buckley leveret equation, impes algorithm, porous media
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Problem on boundary conditions (multi-phase, porous media, 3 flow domains) Juun FLUENT 1 November 19, 2023 02:06
Flow through porous media: permeability issue butterfly1 Main CFD Forum 1 January 2, 2014 03:34
reg Porous two phase flow simulation chittoorreddy STAR-CCM+ 1 December 21, 2009 06:37
Can LES be used in porous media flow? Jin Main CFD Forum 0 October 19, 2006 09:50
