December 30, 2013, 08:19 |
Y plus, fine mesh in wall, error
faza dzulhimam
Rep Power: 13 |
hello everyone, i have a problem about y plus in turbulent flow,
i'm trying to resolve turbulent flow with "STANDARD WALL FUNCTIONS", later, the results will be validated with experimental results the rules for y plus with "STANDARD WALL FUNCTIONS" must be 30 < Y plus < 60, but when i get y plus with range 30 - 60 i have big error after validated, if range of y plus fulfilled, what the results are definitely correct? i used standard k-epsilon model thanks for the help |
December 30, 2013, 08:29 |
Jakob Hærvig
Rep Power: 14 |
How many cells do you place within the boundary layer?
Do you know the thickness of your boundary layer? Guidelines suggest that 8-10 cells should be placed within the boundary layer typically yPlus from 20 to 200. I suggest you have a look at Best Practice Guidelines by ERCOFTAC. |
December 30, 2013, 09:07 |
faza dzulhimam
Rep Power: 13 |
thank you hrvig and thanks for your suggest
is that guidelines for FLUENT ? i didn't see cells in the boundary layer, in near wall, i added mesh with "inflation" with maximum layer => 5 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 09:43 |
