January 9, 2007, 20:44 |
grid sensitivity test
Can someone give a clue as to how to conduct a grid sensitivity test?
I've searched the forum and this is what one of the user recommends: http://www.cfd-online.com/Forum/main...cgi/read/10797 However, he didn't about the size of the domain, in the case of an external flow. So in all (I think) there are 3 parameters to vary: 1. domain size 2. no. of pts 3. grid spacing How and which order should these parameters be varied? I believe the experts here should be able to give a rough guide. Thank you. |
January 10, 2007, 09:08 |
Re: grid sensitivity test
Varying the domain size will give you the influence of the farfield boundaries on your problem. That is, are they sufficiently far away or are they somehow reflecting and affecting your near field solution.
Varying the # of points and grid spacing is really the same thing if you fix the domain size. Systematic reduction in grid spacing (increase in # of points) will give you a measure of your truncation error. You can examine each effect separately and the order doesn't matter. In each case you should create at least three meshes to determine a trend. |
Mapping results from CFD grid to structural grid of a free-form surface | mbecker | OpenFOAM Running, Solving & CFD | 1 | October 18, 2013 11:16 |
A new test harness for OpenFOAM | mbeaudoin | OpenFOAM Announcements from Other Sources | 0 | June 17, 2010 11:36 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
grid on a circle | HaKu | Main CFD Forum | 4 | April 15, 2010 12:56 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 23:26 |
