Free Stream condition
Old   January 8, 2007, 11:35
Default Free Stream condition
shah
What exactly mean by free stream condition? and what is the criteria for choosing it.
if I am calculting flow in a channel for internal flow case and flow past circular cylinder for external flow case . then what should be my free stream velocities and pressure.
My flow equation is 2d Navier stokes.
Thanks
Old   January 10, 2007, 14:58
Default Re: Free Stream condition
Mohamed
The inflow primitive values like M_in, P_in, T_in...are considered as free stream conditions to accelerate the convergence. Since the flow is affected in a small part of the domain(Otherpart remains freestream), this initial condition will work far better than zero initial condition.
Freestream condns are one of the best initial conditions to start the simulation. Since its a uniform value, finally you will get zero diffusion and zero acceleration. so LHS and RHS part of the N-S eqns become zero.
For channel flow and cylinder case, use inflow conditions as a freestream condn,,,,
Bye Mohamed
Free Stream Temperature in natural convection problem tomcatbobby FLUENT 2 January 27, 2011 06:41
Free Stream & Wall Temp UDF jww FLUENT 0 October 2, 2009 10:37
Fluid dispersion into a free stream - Advice needed please LSF FLUENT 0 April 12, 2009 09:45
free stream temperature (boundary conditions) Leentje FLUENT 2 October 11, 2006 09:48
Free Stream R Amini Main CFD Forum 1 May 2, 2002 06:16
