December 26, 2006, 06:54 |
Non-Reflecting BC
I've written my own code program simulating 2D, incompressible and viscous flow about an airfoil. I'm using for that structured C-grid generation (far-field boundary is 15xcord). The problem is that my code program diverges after about 5000 itterations. Mister Ganesh who is an active and helpfull on this Site suggested to use non-reflecting BC at far-field instead of free stream BC. My question is: Are that type of BC can be applied to incompressible flow, and how can i implement non reflecting BC.
December 26, 2006, 17:52 |
Re: Non-Reflecting BC
Most of the non reflecting BC are derived from the characteristics of the Euler equation and they usually try to absorb correctly the outgoing acoustic,vorticity and entropy wave and are derived for systems where the speed of sound is finite.
You can try implementing an absorbing buffer zone.A simple way of implementing it is as follows: The equation would be df/dt=RHS+sigma* f where the factor sigma=sigma0*((x-xb)/D)^beta.sigma0 is a constant based on the grid ( I use sigma0=2/dx for most cases, beta=3 ).D is the thickness of the sponge layer.xb is the location where the sponge layer begins.A sponge layer of 10-20 points works for me. --------------------------------------|------------| xb<---D----->xn I have not tested the buffer zone for incompressible systems and am not sure if they might help. =) |
User Defined Non Reflecting Boundary Condition | Tengc | FLUENT | 2 | November 9, 2021 05:18 |
NRBC's (Non Reflecting Boundary Conditions) | Vinayak Barve | FLUENT | 1 | June 2, 2016 10:42 |
udf for reflecting bondary condition for particle at outflow.. | bhanwar | Fluent UDF and Scheme Programming | 5 | September 13, 2012 03:05 |
Partially reflecting boundary condition | Rachel | FLUENT | 1 | July 1, 2008 19:20 |
Reflecting bc | kupiainen | OpenFOAM Running, Solving & CFD | 15 | July 13, 2005 09:00 |
