backward facing step flow
Old   December 26, 2006, 00:05
Default backward facing step flow
student
im solving backward facing step flow.....how to give boundary condition at the exit. at the exit dp/dx=0 from y=0 to y=H or p=0 from y=0 to y=H im considering the flow is fully developed so at the exit du/dx=0 and dv/dx =0 at the top and bottom walls dp/dy=0 u= v=0 (no slip boundary condition)
at the inlet im giving a parabolic profile before the expansion. please give me the correct boundary condition for pressure. thanks in advance.
Old   March 31, 2009, 07:56
Josy
Josyula is on a distinguished road
Originally Posted by student
;47161
Do you have the C or FORTRAN code for the 2-D unsteady backward facing step in FDM/FVM scheme ?
Josyula is offline   Reply With Quote
Old   February 27, 2011, 03:44
maysmech's Avatar
maysmech is on a distinguished road
;47161
I have these questions too.
I want use Driver and Seegmiller Paper.
What is the inlet turbulence? it is not mentioned on paper.
What should be set for outlet.
what is inlet k and epsilon for this paper?
Regards.
maysmech is offline   Reply With Quote
Old   January 21, 2012, 09:17
Post Help me.
Kyounghwa Kim
Kyounghwa is on a distinguished road
Originally Posted by Josyula View Post
Hello. I'm Kyounghwa.
I have same question.
But, there is no answer.
I have the C code and FDM scheme by projection method.
I give inlet and outlet as follows.
Inlet : u_mean=1, u_max=3/2;
Outlet : u_mean=1, u_max=3/4;
The hight of domain is 2.
The inlet size is 1 and outlet size is 2.
Am I wrong?
ps : I'm reading "A numerical revisit of backward-facing step flow problem" by T.P.Chiang and Tony W.H. Sheu. in 1999.
Kyounghwa is offline   Reply With Quote
Old   January 23, 2012, 10:41
Default Does anybody know?
Kyounghwa Kim
Does anybody know?
Please, give me an idea.
Old   February 17, 2012, 11:54
rmh26 is on a distinguished road
You should look into the open/traction boundary condtion for this sort of flow through situation. A Recent paper "Improvements on open and traction boundary condtions for the NS time splitting methods" by A.Poux JCP 2011
But I guess a simpler answer is that if the flow is steady and parabolic at the outlet then P = 0 at the outlet is ok but the you might be constraining the flow by setting du/dx = 0.
Try extending the domain a little and seeing if the flow changes. Specifically the condition du/dx is not appropriate if you are near the recirculation zone or have any vortex shedding and you can't really be sure that you aren't artificially shortening the recirculation zone by imposing that condition without doing domain independence studies.
BTW I have done this sort of study recently for the axisymmetric case (flow through an expansion) and I using the du/dx = 0 and p = 0 at the exit condition with a long domain if you want to compare results or have further questions.
rmh26 is offline   Reply With Quote
Old   June 9, 2013, 12:17
sahand saghari is on a distinguished road
hi
thanks for your effort
if you have the backward step code,in fortran or matlab, would you send me by this email
aassvvmm@yahoo.com
sahand saghari is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
air-fuel mixing in backward facing step abdullahkarimi Main CFD Forum 0 March 19, 2011 19:39
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Turbulent flow over a backward facing step Jenner Main CFD Forum 1 December 2, 2006 12:21
Inviscid flow over a forward/backward facing step Abhijit Tilak Main CFD Forum 3 February 16, 2005 10:18
