deforming meshes
Old   December 22, 2006, 13:24
Default deforming meshes
dav
hi,
is there some kind of remeshing after several timesteps when using deforming meshes or is there just deformation, so that one can use this method only for oscillatory movement? does anybody know a good paper where I can read about this?
david
Old   December 25, 2006, 09:39
Default Re: deforming meshes
versi
It seems that transfinite interpolation can be used for deforming meshes. but I am not sure which AIAA paper has detail.
Old   December 26, 2006, 01:12
zonexo
If u are using structured grids, u can check out "Unsteady flow calculations with a multi-block moving mesh algorithm" AIAA-2000-1002. Its arc-based TFI is much faster and higher quality compared to Batina's spring mtd. Hope it helps.
Deforming wall problem alxasli FLUENT 3 January 10, 2011 07:22
deforming meshes joseduartedasilva FLUENT 0 August 10, 2010 19:22
Deforming meshes Etienne.P FLUENT 1 October 26, 2005 05:31
IC piston motion - deforming meshes AMV FLUENT 0 September 16, 2003 14:10
Wanted: Examples of Deforming Meshes Greg Perkins Main CFD Forum 3 June 25, 2001 09:10
