December 5, 2013, 18:45 |
how can I use a set of node points
I have a 2D triangular mesh generator that takes in a 2d image with an object of interest inside (like an airfoil or profile of a car) and outputs x and y coordinates for all of the node points. It can also output the three vertices for each triangle. Aside from a plot of these coordinates, that's all I have for a mesh. There is a defined rectangle around the object in the image which could serve as boundaries.
Is there any way I can import that to a mesh generation software that will allow me to apply boundary conditions and output something useful in a solver like fluent or OpenFOAM? |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 13:36 |
How set experimental points values as wind tunnel boundary conditions | vidade | FLUENT | 3 | December 23, 2012 17:02 |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 21:16 |
How to show the transient case? | H.P.LIU | Phoenics | 7 | July 13, 2010 05:31 |
how to set velocity on node | tipakorn | Siemens | 3 | January 23, 2008 06:05 |
