December 2, 2013, 06:41 |
Geometry vs flow direction
I'm new to CFD. I have the following question: Is the flow direction dictated by the geometry you have generated? For instance, if you have generated a vertical circular pipe will the flow be automatically vertical (either upward or downward) on the simulator? Or it depends if you consider gravity? Sorry for what may seem like a stupid question and thank you in advance for your help, VK |
December 7, 2013, 18:09 |
Lefteris
Rep Power: 16 |
I take it you're interested in an internal flow, right?
The flow in the pipe will be driven by a pressure difference. Now whether the flow goes up or down in your pipe, it depends on this pressure difference. If the fluid is not a gas but a liquid, you need to consider body forces too.
Lefteris |
direction, flow, geometry, gravity |
FLuent simulation of taylor couette flow of concentric cylinder geometry. | rshbhb | FLUENT | 53 | November 5, 2014 19:07 |
Can we get two different flow regimes in a single geometry? | TQIM | STAR-CCM+ | 2 | November 25, 2012 23:45 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
Flow direction in Buoyant flow | Nav | CFX | 4 | June 30, 2008 00:50 |
specifying the flow direction in periodic boundary | joanna | FLUENT | 2 | February 27, 2006 21:09 |
