Strain rate calculation for explicitly filtered constant smagorinsky model
Old   December 1, 2013, 09:25
Default Strain rate calculation for explicitly filtered constant smagorinsky model
MMS
cfdmms is on a distinguished road
I have very vague idea about this, if some one help me to understand it will be great help.
In the constant Smagorinsky model, during the calculation of turbulent viscosity (Nu_t) we need the magnitude of the strain rate.
For the implicitly filtered LES, Nu_t will be
Nu_t = (Cs*DELTA)**2*STRAIN_RATE
Where, Cs=0.2,
DELTA= (dx*dy*dz)^(1/3)= almost equal to the cell size (h).
and the magnitude of the strain rate measured for each cell in cell centre (if I am not wrong).
But for explicit filtering, the filter width DELTA will be arbitrary value or multiples of cell size (h), let say DELTA=2*h.
In that case how the strain rate will be linked with the filter size?
Thanks.
cfdmms is offline   Reply With Quote
Old   December 1, 2013, 09:55
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Where, Cs=0.2,
Thanks.
The real measure of the filter widht is somehow uncertain both in implicit and explicit filtering... it is not true that is always delta=2h for explicit filtering, it depends on the effective way you adopt for performing filtering....you can find in literature some papers discussing about that
FMDenaro is offline   Reply With Quote
Old   December 2, 2013, 15:09
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
And the strain rate would be the one based on the filtered velocity. Which doesn't mean it is the best option, it is just how the Smagorinsky model is defined.
sbaffini is offline   Reply With Quote
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
Constant flow rate through a small area inside the fluid domain. robingilbert OpenFOAM 7 October 4, 2010 17:19
