Derivation of reynolds equation
Old   September 9, 1999, 11:27
Default Derivation of reynolds equation
Mark Harten
reading a text book about the derivation of the Reynold's equation I did not understand the following point.
The instataneous quantities of u, v, w and p are split up in an averaged part and a fluctuating part. Afterwards the equations are time-averaged. Why is the density and its fluctuation not taken into account ? Was it a special treatment of an incompressible case in my text book ? (it was not distinguished between compressible and incompressible case)
Could someone give me a reference where the Reynolds' equation are derived in detail for the general compressible case starting from the compressible N-S equations ?
Thanks,
Mark
Old   September 9, 1999, 11:50
Default Re: Derivation of reynolds equation
M. Barbaro
See, for example:
Kenneth K. Kuo, "Principles of Combustion", Wiley, 1986, pp. 412-427
Old   September 9, 1999, 12:23
Hongjun Li
The Reynold's Averaged NS (RANS) equations were derivated (in about 1895 by Reynold) with assumption that density fluctuation was neglected. The averaging procedure for compressible flow is much more complex. If the density is split to R=Rave+R', there are time-averaged (R'u'), (R'v'), etc. terms in the equations. However, very little knowledge is available about these terms. So many investigators have neglected these terms, the resulting equation have variable mean density but additional terms due to density fluctuation are not included and hence, cannot influence turbulent transport.
An alternate approach to variable-density turbulent flow is the use of mass-weighted averaging procedure, sometimes referred to as the Favre Averaging NS equation. I had some references but I lost them when I moved (sorry for this useless information).
Most turbulence models were developed for RANS eqs. and were used for both incompressible and compressible flows. They are still valid according to the Morkovin's Hypothesis which says that the effect of density fluctuations on the turbulene structure will remain small for Mach number below 5 in boundary layers and wakes. You may try to find the following old artical:
Bradshaw, P. "Compressible turbulent share layer." Annual Review of FLuid Mechanics, Vol.9, pp.33-54, 1977.
Hope this will give you a preliminary idea to start with. Regards.
HL
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
UDF Transport equation for transition momentum thickness Reynolds number Wantami FLUENT 0 April 9, 2011 03:50
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
Reynolds Stress equation ??? Abhijit Tilak Main CFD Forum 4 November 15, 2000 07:01
