opening ensight case in open source visualizer
Old   December 14, 2006, 04:21
Default opening ensight case in open source visualizer
clhona
Hi everybody, I have a cfd case saved in Ensight format and I'm trying to visualize it. I've tried many visualizers as Paraview and MayaVi but it crashes all the time! Probably the problem is that my file is too big (.geo file is ~450 MB)...my PC is quite new (P4 4GHz; 1 GB Ram) so I don't think is an hardware problem...any idea? thank you
Old   December 14, 2006, 06:25
Default Re: opening ensight case in open source visualizer
Márcio
Paraview works just fine with Ensight files. If it can't open - and I guess 450 MB isn't too much for Paraview - there could be something wrong with your files.
-Márcio
Old   December 14, 2006, 06:31
clhona
Yes you are right: now I'm trying with a 77 MB .geo file and I have always the same prolem. I found another difference between a case that works and my case that crash: the first format type is "ensight" and the second is "ensight gold" but after googleing it, it seems like there is no problem for paraview with ensight gold...any suggestion? thank you
Old   December 14, 2006, 07:39
Markus Lummer
What kind of cells do you have in your Ensight file? I had problems with n-faced polyhedral cells and paraview.
Old   December 14, 2006, 08:19
William Blake
Paraview will read ensight gold format. So just read the case into EnSight and export the gold-format from there
Old   December 14, 2006, 08:56
clhona
it's mixed hexa-tetra. The mesh was generated with pro-am from star-cd
Old   December 14, 2006, 09:00
clhona
the problem is that I don't have ensight! In fact I use Comet solver and I want to export the case in an open source visualizer: to have a common format I have to save the case in Comet as an ensight file and than read it in paraview
Old   December 14, 2006, 16:20
Charles
"ensight all binary same - - -" works for me to go from Comet to Paraview (reading in as big-endian), but I've only tested that with hexa grids.
A known issue in Paraview is with ASCII ensight files, you need to remove the leading spaces from lines containing strings.
Old   December 15, 2006, 04:10
clhona
I ususally do the same and for hexa grids it works for me too...probably it's about the mixed hexa-tetra mesh...
Old   December 15, 2006, 04:33
clhona
Hi Charles, I tried also with the ascii file but I don't understand where I have to remove spaces? In wich file? thanx
Old   December 15, 2006, 04:47
  #11
Charles
In the various data files (not the case), when you are using ASCII format, there are lines of text headings, at various positions in the files. You need to strip the leading spaces from these lines.
Old   December 15, 2006, 04:51
  #12
clhona
thank you I will try! ciao
Old   December 15, 2006, 06:55
  #13
clhona
no way to do it!I also tried to open the case in an ensight trial version but nothing...
Old   December 15, 2006, 18:59
  #14
Renato.
Hi clhona
If your binary files has been written in a pc, try changing the "byte order" to "little endian".
For ASCII files you must clean the leading white spaces at the end of the lines as Charles said.
Ensight provides a utility called ens_checker which may be useful to discover some problems in your case file. I guess this utility is available in the Ensight's trial copy.
Regards
Renato.
p.s.: Ensight Gold is not equal to Ensight format.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
Could the CFD community benefit from Open Source? JF Main CFD Forum 13 December 18, 2006 00:06
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
