Monika
Rep Power: 12 ![]() |
I have a Windows 7 Home Premium 64-bit PC with a 3 GB RAM and an Intel Core 2 Duo Processor. I am facing the following error while starting up GAMBIT 2.2.30.
[gambit] XIO: fatal IO error 0 (Winsock Error) on X server "MUMU-PC:0.0" after 0 requests (0 known processed) with 0 events remaining. What do I do? Please help! |
Allanson
Rep Power: 0 ![]() |
Maybe your license is expired.
Monika
I believe the Exceed server is not suitable for my platform. I have Exceed 2006.
Allanson
Yeah,you need a Exceed for 64-bit PC.
Maxime Perelli
Rep Power: 41 ![]() |
on win7 (64 bit) I have Exceed 11.0 running with Gambit 2.4.6
In memory of my friend Hervé: CFD engineer & freerider ![]() |
Monika
Thank you. Do you think it would work well with Gambit 2.2.30?
Maxime Perelli
I don't know you have to try.
But if you get Exceed 2006 (v11.0) then get also the "last" version of Gambit. Remember there is no real 64 bit version of Gambit (win). The only one is on linux architecture.
fluent 6.3.26, gambit 2.2.30, hummingbird exceed |
Problem running perturbUCyl | sen.1986 | OpenFOAM | 17 | June 4, 2019 05:56 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
