Fluent and backwards facing step
Old   December 4, 2006, 15:50
Default Fluent and backwards facing step
Ben Sellars
Can anyone send me the fluent tutorial for Turbulent flow over a backward facing step in the Fluent website(http://www.fluent.com/software/studentfluent/lcfd.htm)as i dont have have any access to their website. Or does anyone knwown how to specfy a turblent boundary in fluent, with referance to this problem:
Problem Description: Backward facing step flows involve separation, free shear layers, recirculation region, and flow reattachment. It has important industrial applications, such as in oil/gas pipes and flow around buildings. This case provides a good test to the capability of CFD software regarding the mathematical models (turbulence models), the numerical algorithms, and the mesh sensitivity. After verification of your solution approach, validation can be carried out by comparing your results with the experimental data available by Driver and Seegmiller, which are provided at the module's webCT website.
Figures 1 shows a schematic diagrams of the backward facing step of height H = 1.27cm. The experiment was carried out in a wind tunnel with the step on the floor and the top boundary is the tunnel wall. The tunnel span is 12H.
(figure won't copy and paste) inlet height = 8 H outlet height = 9 H depth/ width/ spanwise = 12H where H= Height of the step
Figure 1.
Inlet Flow Condition: Uin = 44 2 m s-1, Min = 0.128, at atmospheric total pressure and temperature.
The turbulent boundary layer thickness at 4H upstream of the step:  = 1.9 cm
Note that the boundary layer thickness is significant in comparison with the step height. It is therefore important to match this condition as closely as possible. This can be done by (1) extending the upstream channel length; or (2) specifying a turbulent boundary layer distribution at x = -4H.
Only the undeflected upper wall case is considered in this assignment.
Old   January 8, 2007, 02:02
Default Re: Fluent and backwards facing step
wael
I hope you got any help. I also need that tutorial. if you have it please send it to me.
Many thanks
Old   February 3, 2007, 13:36
arjun
i need a tutorial on backward facing step and data on reattachment length.. please help
convert *.msh to *.stl and backwards Lilly ANSYS Meshing & Geometry 2 October 22, 2017 21:03
Backwards compatibility of Fluent 6.3 with 6.2 Brian FLUENT 1 April 4, 2007 22:52
CFX vs STAR-CD and Fluent William CFX 20 October 29, 2001 14:55
