Solid-body Swirl with k-eps Turbulence Model
Old   December 4, 2006, 09:26
Default Solid-body Swirl with k-eps Turbulence Model
Werner Lahat
Hi everybody,
I am currently doing some validation work before I will do some transient in-cylinder engine-calculations. After checking the convection-and diffusion-terms in my CFD-code, I want to check the Source and Sink terms of my turbulence equations. Testing the Dissipation term is pretty easy, because if I have zero velocties everywhere, the intial turbulence just decays. You can even derive an exact solution for this case. Testing the production terms in the k-eps-equations seem to be more difficult. One example I could think of, would be the decay of turbulence and momentum in a cylinder initialized with a solid-body velocity-field and uniform distributed turbulence quantities. Does anybody know about papers or publications regarding this testcase?
Regards,
Werner
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 12:13
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 07:12
Turbulence model Herry Phoenics 1 May 29, 2003 14:19
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
